QTP electric cutout question
Old Mar 16, 2006 | 03:59 PM
dragonZ28's Avatar
Exclamation QTP electric cutout question
Okay guys, quick question.
I installed my switch today. I hooked the hot wire to the aux power source on the driver side of the car, and I connected the ground wire to ground.
Here is my current position. When the switch is in the neutral position, the light is lit - even when the vehicle is off. No matter where I tap this into, the light will be lit when the car is off. Is this thing always supposed to be lit in the neutral position, or only when the ignition is on?
I'm afraid this thing will kill my battery over night. Thanks guys!
Old Mar 16, 2006 | 04:09 PM
2001NBMZ28's Avatar
I had mine connected (power) to the radio fuse - light stayed lit until I opened the door. Supposed to get power from a "switched" power source.
Old Mar 16, 2006 | 04:13 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
.. mine is to the TRACTION CONTROL switch...off when key is out.
Old Mar 16, 2006 | 04:42 PM
dragonZ28's Avatar
I fixed it. I just put the hot wire into the "gauges" fuse.
Old Mar 16, 2006 | 04:51 PM
bowtieman81's Avatar
Yep, you just need a switched power source for it. Otherwise it will drain your battery.
Old Mar 16, 2006 | 04:57 PM
roughneck427's Avatar
Yup what ^^^^^^^^^^^ said
Old Mar 18, 2006 | 11:46 PM
Havok2's Avatar
i bought a elec cutout used, anyone have wiring diagram or anything? do i just ground 1 wire to the body of the car and 1 i link it to the radio fuse??
Old Mar 19, 2006 | 02:40 PM
Jeremiah's Avatar
My QTP fell appart in only seven months of ocasional weekend cruising, keep an eye on it.
