LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Bolt size for rear o2's?? (https://ls1tech.com/forums/generation-iii-external-engine/476964-bolt-size-rear-o2s.html)
SteveDoten@ARH Mar 26, 2006 08:47 PM
had the rear o2's disabled, what's the bolt size? need to fill the hole, thanks
Juiced2000SS Mar 27, 2006 11:37 AM
I think it's 18mm but I am not absolutly sure. If you have a Napa near you they will be able to get you fixed up. Just take an O2 with you and they will be able to find what you are looking for.
daryl2cb@yahoo.com Mar 27, 2006 12:52 PM
there are also plugs that are like that of the big fleeze plug in the block that use can use, I would not use a bolt.
2K2WS6TA Mar 27, 2006 05:40 PM
Why not just use the old o2 sensors, they're free, and you have them(I'm guessing), just don't hook up the wires
mcamp001 Mar 27, 2006 08:24 PM
but an O2 would slightly restrict flow because it sticks out into the pipe, lol, just kidding, but it is true. Contact Stainless Works, ask for Al, they have the correct plugs in 304 stainless, and they have zero depth to the inside.
SteveDoten@ARH Mar 27, 2006 08:28 PM
it's a vette, having Kooks on the car makes for a tight fit on the wiring, i'll have to match the threads, suprised nobody has the spec on the thread size?
mcamp001 Mar 27, 2006 08:31 PM
I am not positive, but I think they are 18mm x 1.5, but please check before you buy something
SteveDoten@ARH Mar 28, 2006 09:50 PM
your right, M18x1.5, no shops around here have that size, the commercial plumbing w/h's only deal w/ npt and american
2K2WS6TA Mar 28, 2006 10:17 PM
Try Earls, I think they make an AN plug in that size
AnthonyR Mar 28, 2006 10:35 PM
found some at ACE hardware a while back
© 2026 MH Sub I, LLC dba Internet Brands
