Car troubles again....HELP!
Old Jul 30, 2002 | 04:09 PM
BIGBOS's Avatar
Default Re: Car troubles again....HELP!
Yes, its still tapping...
Any more ideas?
It knocks pretty bad for have only sprayed a 75 shot of fuel at it... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 30, 2002 | 10:04 PM
ArcticFormula's Avatar
I really don't know much about cars, but prehaps what RPM WS6 said makes sense. The CPS as a culprit. I saw this thread as well:
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=001884
I also saw this tidbit of info on http://www.automotiveforums.com/vbulletin/t476.html
Specifically:
"Also new on the 2001 models is the reluctor wheel which is attached to the crank to trigger the crankshaft position
sensor which is now redesigned to enhance signal output."
Is it possible a 98 PCM Flash is not compatable with a 2001 with respect to a CPS signal? I guess this would have been identified with others if it was an issue, but like I said I don't know much about cars and just thought I would throw that out there.
Regards,
Old Jul 31, 2002 | 01:36 AM
flyin red TA's Avatar
You sure the tapping isn't an exhaust leak? Does it tap all the time?
I'm off wed. so call me and I might be able to check it out.
<small>[ July 31, 2002, 01:38 AM: Message edited by: JimTA ]</small>
Old Jul 31, 2002 | 10:19 AM
BIGBOS's Avatar
It didn't tap ever before, it taps now though, thats an interesting thought about the wires though...
Old Jul 31, 2002 | 11:21 AM
BIGBOS's Avatar
TTT
Old Aug 1, 2002 | 12:05 AM
WILWAXU's Avatar
Moving to internal engine
