what's needed 2 intall ls6 intake on 99ta? <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /> |
Re: what's needed 2 intall ls6 intake on 99ta? LS6 intake, one new coolant bypass line and 2 blockoff plates. Everything is O-ring, so there are no gasket issues. Install is not too tough. |
Re: what's needed 2 intall ls6 intake on 99ta? where can I get this coolant bypass line? gm part? part # pics? |
Re: what's needed 2 intall ls6 intake on 99ta? GM part# 12568478 (cross over tube) just had one put on my 99 T/A |
Re: what's needed 2 intall ls6 intake on 99ta? Usually when you get the intake it will come with a kit or you can buy it seperately. It will have to plugs and one pipe. Real easy install. The map sensor on the back is the toughest part. http://home.austin.rr.com/jmx/car/mo...d/install.html This is a good write up about it. |
Re: what's needed 2 intall ls6 intake on 99ta? wow that's a big help! thanks blur! |
Re: what's needed 2 intall ls6 intake on 99ta? When I installed my LS6 manifold, I didn't do anything to the coolant pipe going across the front between the heads, just bolted it on. Is there any danger of harming anything? It seemed to bolt right on! GregM |
| All times are GMT -5. The time now is 12:42 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
