A4 guys with UD Pulley
In the Future I want to put on a SLP pulley on my A4... My question is do I need a new tension pulley? Do I need alt. pulley on an A4 car.. Is it a good mod for an A4?
Board Certified Idiot
No you do not. If you dont have tons of other items in your car Drawing power then you should not. your car will allways Remain in a open loupe at idle.
I had an ASP pulley put on my A4 and I had some problems. You may want to change the alternator pulley, I think that would be a good idea.
When I had the pulley on I noticed that my turn signals were working real slow because my car was discharging at idle speeds. My stock battery went dead after a few months. It also effected my power steering at idle speeds as well, and that's when you need it the most, while parking in tight spots.
Hopefully you won't have the issues that I did. I'm glad I took it off.
Good luck.
Good luck.
