View Poll Results: Did you break you oil pressure sensor?
Yes, I broke it.
20
46.51%
No, I am damn lucky or lying.
23
53.49%
Voters: 43. You may not vote on this poll
Broken oil pressure sender w/ intake swap
14 Second Truck Club
So who here broke their oil sender when they removed or installed their intake? Be honest! After doing a search last night after mine I found out it was pretty common. So, Yes-or-No?
I second that, plus if you actually do some reasearch first, you will see hundreds broke thiers, so this should be a heads up. No for me. TIP follow the hose from the brake booster to the manifold, it runs behind the sender, pick the hose up with your thumb on the sender, easy as up and over. I can not tell you how many times I have typed that. BEST NEWBIE TIP EVER!!
LS1Tech Sponsor
I busted mine! but i've only pulled the intake once and it happened! I was so excited to finally get all those pesky bolts out and all the **** unhooked that i just yanked and totally forgot about that thing back there, lol
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I have removed 5 intake manifolds and broke it once so i think thats a good record. Although ive also learned that if you remove the hose from the break booster that connects to the break booster and the back of the intake manifold it wont break because that hose runs behind the sensor and when you pull on the intake manifold that is what pulls the sensor forward and breaks the sensor.
LS1Tech Sponsor
how do you get that sucker off the back of the intake when its way back there? I couldnt even get the sucker off the intake when i pulled it out of the car so i just shipped the intake off for paint with the brake booster attached, lol
__________________
That's what she said...
Originally Posted by keliente
I didn't break mine and when I did that install, I was thinking that breaking it would be pretty impossible unless you were going king kong on the damn thing and ripping it out.
Originally Posted by TheBlurLS1
It's the plastic part that sticks up that usually breaks off.
on a separate note, i for one have not broken mine
LS1Tech Sponsor
Yea, be very careful you dont break yours.... I just busted mine and it was $49.73 . Nice thing that my dad is a dealer so he got it for $37.30 . Now i still gotta buy the tool. Be careful!
__________________
