LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   installed Ls6 intake.. now my AC doesn't work. (https://ls1tech.com/forums/generation-iii-external-engine/48926-installed-ls6-intake-now-my-ac-doesnt-work.html)
Matt2000ss Sep 21, 2002 08:49 PM
I just installed an intake manifold and have the scars to prove it.. I was driving around a bit to help the computer along.. well I turned on the AC to see if the car would die or not... We I could hear the usual sound of the AC kicking , but NO airflow at all came through the vents.
I installed the intake.. and removed the AIR/EGR/Pump stuff.
Did I remove something I should not have? forget to reconnect something?
Im in the texas heat so I'm really in a bind right now.
Thanks.
SSBoy Sep 22, 2002 12:42 AM
Re: installed Ls6 intake.. now my AC doesn't work.
I think you pinched a line. I remember hearing from someone that it happens quite frequently on those intalls if you not paying the most extreme attention when installing it.
someone help me out here???..i forgot what its called..
Trace Sep 22, 2002 12:45 AM
Matt, you have a small hose that hooks to back of the manifold . You probably forgot to plug it back in or it was loose or check on pass side for small a/c vac line. I can almost gaurantee it is one of the two.
Regards
Trace
jmX Sep 22, 2002 03:28 AM
If you dont hook up the tiny vacuum line on the back of the manifold (it commonly comes disconnected while isntalling the manifold) then your A/C will come out the defrost vents.
Matt2000ss Sep 22, 2002 11:11 AM
thanks guys, noone on ls1.com responded to my thread.
I'm gonna go check out the back of the manifold and I hope its just that disconnected vacuum line.
jmX Sep 22, 2002 01:03 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Matt2000ss:
<strong>it feels like the little vacuum line IS connected , but the AC Does come through the defrost vent</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hrm, something is definitly wrong with that vacuum line. The vent director thingy is controled via vacuum, so its not like anything else could really be wrong besides that hose (plus the fact that I've had mine disconnected accidently 3-4 times in the past 2 years). There is a tiny rubber 90 degree boot...one end goes to the manifold, one end goes to the little vacuum hose. Make sure both are connected as both can come loose.
jmX Sep 22, 2002 01:05 PM
One more thing, you can accidently PINCH that line under the back of the manifold if you aren't careful. Feel back there and see if you did that.
Matt2000ss Sep 23, 2002 12:44 AM
© 2026 MH Sub I, LLC dba Internet Brands
