LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   O2 Sensor's (https://ls1tech.com/forums/generation-iii-external-engine/492391-o2-sensors.html)
BLACKOUTZ28 Apr 20, 2006 08:31 AM
O2 Sensor's
Hey guy...well I dont really know whats going on with my car! It runs really crappy, feels like it wants to turn off, and smells really bad. My friend that did the tunning on my car told me that my O2 Sensors are going bad...so I think its time to replace them. So I wanted to know.....
Which O2 Sensors to get?
Where do you get them?
How much do they run?
Steve
carrsls1_camaro Apr 20, 2006 08:35 AM
Once again this is a item I would go back to GM for. I have run the parts store brand and they jsut don't last on a modded car very long and cost almost the same money.
Shallow Bay Apr 20, 2006 08:47 AM
Bosch part number 13111
Autozone
Around $130 for both
carrsls1_camaro Apr 20, 2006 08:49 AM
I think you can get them from GM for about the same money.
Shallow Bay Apr 20, 2006 08:59 AM
LT = Bosch
BLACKOUTZ28 Apr 20, 2006 08:59 AM
Thanks for the info stillremains
BLACKOUTZ28 Apr 20, 2006 09:34 AM
Well I found out that the O'Reilly near my house has them in stock right now...do you guys think the car will run okay if i just replace the driver side sensor.
Steve
Domestic Demon Apr 20, 2006 10:14 AM
Steve
I'd replace both just to be on the safe side. Then you will know for sure if the problem was with the oxygen sensors and not somthing else.
LS1MONSTER Apr 20, 2006 10:41 AM
Are you getting any check engine lights/DTC's..did you see the live data on the O2's are they lazy and if so is it the both front or just one?.. you could always swap out the rears to the front and vice versa. O2's are expensive just make sure you know whats up before you dump money on them. Might need to run the Corvette 02's since your running LT's.
BLACKOUTZ28 Apr 20, 2006 11:09 AM
Yes I have the "SES Light" on my way to work this morning it was flashing and the car was bogging really bad. Only the driver side was throwing a code the last time I checked..I think it was low circut not to sure.
Thanks for help guys.
Steve
LS1MONSTER Apr 20, 2006 11:21 AM
Flashing check engine light means the engine is miss firing IIRC..might be more than just your 02's. Should have it scanned again.
Z28LS1camaroguy Apr 20, 2006 01:57 PM
yeah my SES light came on today and wasnt flashing, i know for sure its the o2 b/c the connector was burnt through to the wires from contacting the header. You might want to check your plugs and plug wires while your tryin to fix it, your o2s may be bad and caused the spark plugs to foul up from the crappy 02.
273sunsetZ Apr 20, 2006 03:00 PM
I replaced all of my 02's at one time, and within a 6 month period they were all bad because of my catts being clogged.
2K2WS6TA Apr 20, 2006 05:39 PM
I used the bosch 13111s on my headers, got them from a non sponsor, for $125 (saved quite a bit over buying them locally)
If you want the site, PM me
© 2026 MH Sub I, LLC dba Internet Brands
