LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   need help with 02's....... (https://ls1tech.com/forums/generation-iii-external-engine/49266-need-help-02s.html)
2QuikTA Oct 9, 2002 11:19 AM
put my hooker lt's and ORY the other week and at first everything was fine but now i'm getting 2 02 codes....anybody shed some light on this
0131-02 Sensor Circuit LOw Voltage (Bank 1 Sensor 1)
0151-02 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
And yes they are plugged in....
2QuikTA Oct 9, 2002 11:21 AM
Re: need help with 02's.......
Also will driving the car with these codes mess anything up?
TXCAMSS Oct 9, 2002 02:42 PM
I am taking a shot in the dark here , but make sure that you plugged the front ones in to the front connectors and simms in the rear O2s. It sure seems strange that both front O2s threw a code. I would double check them and make sure they aren't pinched or melted against something causing them to ground out. If that doesn't work swap out the O2s with the ones that were in the back of the cats and see if that clears it up. I guess it's possible that you went pig rich and fouled out the O2s , but I have never heard of that. Good luck.
James
50ETR Oct 9, 2002 05:07 PM
WOW, now I feel better about my problem. I did the exact same install on my car and 2 weeks later the 02's fried out. I wonder if it is the Hooker Longtubes!!!
I took my car to the dealership and they first thought it was my MAF Sensor and replaced that then they replaced my 02's both of them. HMMMM, I Just hope they will stay ok and not blow out again. I will keep you posted about how it works out. If you go back a couple of days possible and look at the post I made about SES light after header install you'll see what i mean. Tell me if that is what happened to you...
2QuikTA Oct 9, 2002 06:50 PM
the question is.....is it ok to drive the car under these conditions until i can afford some 02's?
Could running too lean take out the 02's? Before the codes hit I set the maft a little too lean and threw a too lean code(don't have atap). I richened it back up a little and then today the 02 codes hit. Could it be the 02 extensions from hooker maybe?
50ETR Oct 10, 2002 10:34 AM
Well I know it isn't a good thing to run when the 02's are shot because it will trip the computer out and end up running you really rich or really lean. Or in my case both!!!
I took mine into the dealership because I hve the 100k extended warranty and they replaced them both. Even though I have Hooker Headers and Off-Road Pipe!! Cool dealer huh!
They are ok so far but I am waiting to see if i blow them out again!!!
© 2026 MH Sub I, LLC dba Internet Brands
