TSP True duals hitting tranny crossmember
I'm trying to put on my true duals but they are hitting the crossmember. I think it's because I have an LT1 with jethot headers that have a 3 bolt flang, and I put on short header extensions since the tsp true duals are a 3-bolt flange design. Would it hurt anything if I notch the crossmember at all?
Originally Posted by 30thanniversaryZ28
I wasnt aware that the TSP True duals worked with LT1s. I guess i should have figured since all fourth gens have basically the same undercarriage.
Originally Posted by speed_demon24
I think I can get them to fit, the only thing I see that I had to do was buy header extensions since I don't have slip fit headers, and one side seems to be about 6" too long before the x-pipe, so I can just cut the pipe I guess.
Well hope ya get if figured out. Im lookin at gettin true duals for my LT1 but wasnt sure as to what to get. Post some pics if you can.
What kind of headers do you have? I'm going to try to finish up the instal tomarrow.
cross, crossmember, crossmembers, crossmemeber, duals, hitting, ls1tech, lt1, member, miami, suspension, true, tsp, umi, works
