two mufflers in back?????????
Old Apr 26, 2006 | 10:11 PM
layz's Avatar
Default two mufflers in back?????????
i have a friend that wants to put two mufflers in back like the new mustang. lets say two single chamber flowmasters. what would it sound like ..... the exhaust would consist on headers and offroad ypipe going over the axle to two single chambers (or muffler of choice) anyone do this or give some advice on this.....
Old Apr 26, 2006 | 10:21 PM
SUX2BU's Avatar
Theres only one way to find out
i don't think it will sound bad, infact it might sound pretty good. All exhaust sounds different. It might be too quiet though.
Old Apr 26, 2006 | 11:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Flowmaster actually makes a setup that replaces from the axle back on the new mustang. It could probably be used for this too.
Old Apr 27, 2006 | 12:04 AM
Starz T/A 17's Avatar
yeah flowmasters usually sound pretty damm good on stangs plus they have TD's from the factory which helps
Old Apr 27, 2006 | 12:05 AM
grubby98's Avatar
i have a custom made true dual x pipe that goes into 2 2-chamber flowmasters and it sounds pretty damn good. not that loud at idle, but when you get into it, it really opens up.
Old Apr 27, 2006 | 12:09 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I actually can vouch for the Flows on the new mustang GT. They sound amazing over the stock setup.
Old Apr 27, 2006 | 08:20 PM
layz's Avatar
this is for a camaro not a mustang and it does not have true duals it has a offroad y pipe it will have two mufflers in back it will y into to mufflers yes or no on the sound. i do not want to do true duals. i want to keep my offroad y pipe.....
Old Apr 27, 2006 | 08:51 PM
daryl2cb@yahoo.com's Avatar
?? It will not fit, and if it does it is going to cost a fortune to fab up, plus it would all be worthless with flowmasters on it. you might be able to squeeze to magnaflow bullets under there, but I do not understand the login here, basically it will sound the same if not quieter, plus it would add more weight, hang real low and look not to good in my opinion. even true duals do not hang two out back
Old Apr 27, 2006 | 08:55 PM
Zinc's Avatar
Somebody on here has a custom dual muffler setup (I think he used Remus mufflers made for a 8 series BMW or something) and it sounded and looked BADASS. I say go for it, because I was thinking of trying it too...
Old Apr 27, 2006 | 09:34 PM
grubby98's Avatar
mine is fabricated by a local exaust shop for a little over 500. its true duals(X) over the axle with 2 2-chamber flowmasters. so it can be done and it doesnt cost that much either.
Old Apr 27, 2006 | 09:39 PM
SiL3NtXWS6's Avatar
2 mufflers (that aren't bullet style) = 2 heavy 4 me
Old Apr 27, 2006 | 10:05 PM
02TransAm/Batmobile's Avatar
for one, . . its not a mustang, . . and two if you want that set up you'd have to go true dual
Old Apr 27, 2006 | 10:08 PM
00SLPSS's Avatar
I don't see it sounding much different beings you want to keep the y pipe in there.
Old Apr 28, 2006 | 02:46 PM
layz's Avatar
02transam/batmobile why would i have to do true duals i would actually have exhaust setup like the corvette in a way except just have a offroad ypipe going over the axle then split off to two mufflers with tips coming off the mufflers....
Old Apr 29, 2006 | 07:14 PM
lsx24's Avatar
Ls1speed used to have a custom true dual that utilized ATR mufflers although I don't see them there anymore:
Old Apr 29, 2006 | 07:17 PM
MeentSS02's Avatar
Kleeborp the Moderator™
That's because they had to beat the **** out of the t-top storage area to get those to fit...they have since switched to the mufflers I have now (Magnaflow 10416):
Old Apr 30, 2006 | 11:35 AM
lsx24's Avatar
I'd be interested to know to the best of your knowledge was it just a pain in the *** or, did it reduce the space where the ttops normally would go.
Old Apr 30, 2006 | 12:41 PM
Viper's Avatar
Several years ago I bought bullets that doubled as tips and used them in the back after a custom-y over the axle, looked like the picture 2 posts above but went all the way out the back. Sounded awesome, just a little too loud with cam and heads.
Old Apr 30, 2006 | 02:16 PM
MeentSS02's Avatar
From what I could tell, it was more of a PITA than anything...you could get away with no clearancing of you tilted the mufflers, but then you risked being able to see them from the back (instead of tucking up so nicely).
