LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   pacesetter LT's shopping list (https://ls1tech.com/forums/generation-iii-external-engine/500560-pacesetter-lts-shopping-list.html)
milleniumZ28 May 3, 2006 10:35 AM
let me know what i am leaving out, 02 extensions for the front, 02 sims for the rear, plates to cover the EGR. anything else since i am planning on removing the EGR, AIR, and cats.
ohsofast May 3, 2006 11:38 AM
Header gasket, new spark plugs, plug wires, anti seize, zip ties. You should be good after that
TWS May 3, 2006 11:47 AM
Don't get their OR Y-pipe. Mine bangs the floorboard like a mofo and I have heard similar feedback from others. I'm eventually going to pull mine off and give it a "hammer mod", but have been too busy/too lazy.
2K2WS6TA May 3, 2006 04:55 PM
Plug for the intake (where the EGR pipe enters) plates for the air too (unless you're getting race headers) and an appointment with a tuner to get rid of the SES light (from AIR/EGR removal)
WhiteKnightZ28 May 3, 2006 06:10 PM
Get a 1-3/8" Ajustable freze out plug for the intake, mine cost about $3 at the local parts store, It looks like a big washer with a little nut on top and a big piece of rubber on the other side.
milleniumZ28 May 5, 2006 12:00 PM
do Pace setter headers come with o2 extensions and the header gasket
Shallow Bay May 5, 2006 03:10 PM
Pacesetter headers come with wire and crimp connectors so you will have to cut and splice the original wires to extend them. As for the header gasket, they supply you with a paper one but it will end up leaking.
TheBlurLS1 May 5, 2006 03:19 PM
Check the FAQ at the top of the page. You'll find info a few posts down about O2 extension information.
Since you will be dumping the AIR and EGR, you will get the SES light from removing those. O2 sims on the back would be a waste of money. You are going to have to have a shop with LS1edit or HP tuners remove the codes to stop your SES light.
Use the stock gaskets, or new OEM ones. I would also suggest throwing in a set of Poly-motor mounts while you have the exhaust out. It will solve problems before they start.
Try a search, or at least read through the page. You will find tons of information.
© 2026 MH Sub I, LLC dba Internet Brands
