6 Liter Block Problems Bolting Up Alternator...
I just got my 408 from FFHP and I was bolting up all of the accessories and for some reason, the provisions for the alternator are not the same as my stock LS1 motor. What are you 408 and iron block guys doing to mount the alternator up? I can get the bottom bracket bolt and side mount to the block on but the center short bolt and top bolt for the support bracket are laughing at me with no holes provisioned. Any help would be greatly appreciated!
Thanks guys.
Dustin
Thanks guys.
Dustin
Originally Posted by 99whitews6
I know. I have an 01 block. I think I used like two of the four bolts needed. Works fine.
any idea what size tap? im at work and i want to pick one up on my way home as i need this car done ASAP can anyne think of any other issues wiht putting a 01 iron block in my f-body i dont want to get stuck again.
The one I used was a 10mm x 1.50. I dont know what size drill bit I used, since i cant seem to find it anymore. I just took the bolt to a few places, and did some searching to find the right size. I had the best luck at Ace hardware. Hope that helps out some.
