Will TSP TD work with UMI trans mount adj. torque arm ?
Will TSP TD system work with UMI trans mount adj. torque arm ? also, with all my mods, can I just keep using the stock one ?
Hello,
The pictures below show our transmission mounted torque arm installed with the TSP true duals If you have any questions please ask and I will be glad to help.
http://www.umiperformance.com/images/2205l.jpg
http://www.umiperformance.com/images/2205m.jpg
http://www.umiperformance.com/images/2205o.jpg
http://www.umiperformance.com/images/2205p.jpg
Actual torque arm link- http://www.umiperformance.com/2205.aspx
Hope that helps,
Ryan
Hope that helps,
Ryan
Thanks a lot Ryan, thats fits perfect, that's what I'll go with than, I hope it will fit that well on my car too. lol one more think, is there any reason not to get the adjustable one and save some cash with the regular non-adjustable ?
Glad to help
Our torque arm actually adds some addtional room over the stock arm to tuck the TSP system up tighter against the floor.
As for adjustable, since your vehicle is lowered I would highly recommend the adjustable version to get your pinion angle set back where it needs to be for the best traction. When you lower the vehicle it changes the driveline angle causing addtional traction loss. Also if you are looking to get the best possible traction and 60-foot from the vehicle the adjustable is the best way to go. If the car is more of a street car and you aren't worried about the pinion angle and want it more for a little extra bite then the non-adjustable would work just fine.
If I can help anymore please ask. Thanks
Ryan
Ryan
That's what she said...
Awesome posts UMI! I've been scouting around for a new TQ arm for mine. I've got the TSP duals and my stock TQ arm clears by about 1-1.5".
I'll probably give you guys a shout pretty soon about it. My car is lowerd about 1" in the rear now, going deeper sooner. I'd like to cut better than a 1.95 60' next time I go!
Yup, that's what I want: best possible traction and 60-foot times.
Adjustable it is !!!
Thanks again Ryan - You guys are doing a great job there at UMI,
HIGHLY RECOMMENDED TO EVERYONE !!!
looking at the pics I noticed the tq arm is connected to the trans. I could'nt see where the tq arm is mount at from the trans end. so I'm assuming it's still connected to trans. would TSP's td still fit with UMI trans mount w/ d/s safety loop?
cowboysfan
cowboysfan
