Help Me Install My Catch Can Please!!!!
Old Jun 9, 2006 | 03:38 PM
TheBlurLS1's Avatar
That's what she said...
Originally Posted by JD17825
I have that same can why is there still a need to use the pcv valve ?
Well it definatly isn't going to cause MORE consumption is it?
I think it's used to regulate flow when you go WOT so that you don't suck a half gallon into the manifold.
Old Jun 9, 2006 | 05:26 PM
JD17825's Avatar
just wondering because ive taken mine off and it dosent seemed to be consuming oil but ive been looking at all the pics and think i might put it back in
Old Jun 13, 2006 | 02:00 AM
JerikSS's Avatar
Would installing a breather help?
Old Jun 13, 2006 | 08:23 AM
TheBlurLS1's Avatar
It would negate the catchcan. The PCV system and catchcan setups work off of a pressure differential between the intake manifold and the throttle body (before the blade) to pull air through the crankcase via the fresh air tube on the TB. It is then sucked out through the PCV system back into the manifold to be burned.
Old Jun 23, 2006 | 01:02 PM
FireSilverLullaby's Avatar
I just got the same catch can from ebay. Im gonna install it today.
Old Jun 23, 2006 | 02:57 PM
Cooper01Z28's Avatar
cool cool, it work pretty good
Old Jun 23, 2006 | 04:08 PM
candidate zero's Avatar
Good find on the catch can, that's an awesome deal.
Old Jun 23, 2006 | 06:35 PM
Yeah it is just trying to figure where i want to mount it now.
