Post if you have MAC MID LENGTHS and your car makes blue smoke!!! i have mac mids and am considering different headers after reading all the posts about people with these headers and for some odd reason them causing oil consumption :chug: either way still changing the headers or going back to stock manifolds but just wanted to see. :) |
you check your PCV? Is it only under WOT conditions? |
havent checked the pcv fixing to upgrade to ls6 with a catch can and Yes WOT |
You have oil in the intake? Are you cammed? Please tell us your setup. I am really curious due to a problem that I have had with this on a cam/header swap. |
I have Macs and NO smoking. I remember this issue was being debated years ago...I don't remember if there was ever an outcome. Personally, I fail to see how a set of headers could cause an engine to burn oil. |
I had Mac's and a smoking problem. Nothing a new set of heads didnt fix. I too find it funny that a exhaust manifold could cause a smoking complaint. The only thing I see through my shop would be if you took you cats off. I had cars that I had taken cats off then started to have a slight smoke complaint. Because the cats covered it up. John |
Ok. How does an exhaust manifold or header have anything to do with smoking/oil consumption. WTF :confused: It should have nothing to do with exhaust. |
Ckz what year is your car??? |
I have a 98. FWIW, I also have a cam and don't run any cats. Your smoking issue is related to one or more of the following: -PCV system -Valve seals -Rings |
You would think that it is just blow by that was causing the problem. I still have a really hard time believing that it is caused by headers. |
yeah ive heard piston ring flutter, pcv which i am getting a catch can for, and valve guides which i doubt, funny thing is the car still runs like a scalded dog and its just for a second its not like it does it in every gear is just a poof at WOT. |
Originally Posted by orangeapeel You would think that it is just blow by that was causing the problem. I still have a really hard time believing that it is caused by headers. |
Originally Posted by just1news6 yeah ive heard piston ring flutter, pcv which i am getting a catch can for, and valve guides which i doubt, funny thing is the car still runs like a scalded dog and its just for a second its not like it does it in every gear is just a poof at WOT. Sounds like a PCV issue to me :) |
it may be i have no cats as well i guess well try it and see |
© 2024 MH Sub I, LLC dba Internet Brands
