Fernco Mod How big is the inlet and outlet suppose to be? |
Re: Fernco Mod The 3" fernco coupling works a little microwave time is needed to fit over TB. Good luck! It takes a quick person to put it on before it cools. |
Re: Fernco Mod </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Inspector12: <strong> The 3" fernco coupling works a little microwave time is needed to fit over TB. Good luck! It takes a quick person to put it on before it cools. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't get it... I measured the OD of my throttle body TODAY, and it measured 4 inches!! The MAF ends are about 3.5 inches... How does a 3inch hose fit on a 4 inch pipe? Do you microwave it for 2 hours?!!? Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> |
Re: Fernco Mod Just take your MAF into the store with you and get one that matches. FYI...it is kind of a PIA to do. You have to heat it, fit it on, let it cool, check the fit, repeat as many times as needed (it took me 3 or 4 times). Then to make it really fit nice, you need to cut the ends (at least I did) to make it alighn right (the TB is lower than the lid). Also, to do this mod, its a good idea to have a poly trans mount to keep the engine from twisting too much. People who did not have the poly trans mount have said that when the engine torqued up, it pulled the coupling off of the TB or MAF. Even worse, some have had the engine torque enough that over time, the little tabs on the back of the lid broke off (no more lid <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> ). I'm not trying to scare you away from it, I'm really happy with it now that its on the car. It works wonders and I'm always getting people asking "where did you get that, it really looks good." Chris |
Re: Fernco Mod No poly mounts here. Fernco hose on for over 2 years. No problems. Good cheap mod for less than $5. |
Re: Fernco Mod </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TaTommyWS6: <strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Inspector12: <strong> The 3" fernco coupling works a little microwave time is needed to fit over TB. Good luck! It takes a quick person to put it on before it cools. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't get it... I measured the OD of my throttle body TODAY, and it measured 4 inches!! The MAF ends are about 3.5 inches... How does a 3inch hose fit on a 4 inch pipe? Do you microwave it for 2 hours?!!? Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Here's mine: It works great! I believe I have the 3x3". Microwave for 1 minute so it becomes pliable. Edit: pic didn't work <small>[ April 07, 2003, 07:55 AM: Message edited by: unit213 ]</small> |
Re: Fernco Mod Thx for the help guys! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> |
Re: Fernco Mod I bought a "hump hose" from an air supply company in Bend, OR. (I'll try to find their web site). It was $14 shipped, and looks like the SLP bellows. I ordered a 3.5 " - 4" since it measured the same as the TB and MAF, but the 4" was too big. So I had them ship me a 3.5 - 3.5 and it fit perfect. It took a little stretching to fit it over the TB, but the install still took less than 5 minutes. |
Re: Fernco Mod Just fill up your sink with HOT water and it'll slip right on. No problems here whatsoever. </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris99WS6PWTMET: <strong> No poly mounts here. Fernco hose on for over 2 years. No problems. Good cheap mod for less than $5. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"> |
Re: Fernco Mod you know why it fits and it says its a 3in hose because it is made to fit over 3"pvc pipe which measures 3.5" outside diameter and 3" inside just thought i clear that up |
© 2024 MH Sub I, LLC dba Internet Brands
