LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   ASP install-can't be right?(PICS) (https://ls1tech.com/forums/generation-iii-external-engine/53184-asp-install-cant-right-pics.html)
mattbta Apr 24, 2003 03:41 PM
So I finally got around to getting an ASP pulley and installing it. Got stocker off fine, trying to put asp on now. However, I can't turn the bolt anymore and it's around 200 ft lbs on the torque wrench.
Weird thing is, take a look at it.....it appears to still have a good quarter inch before it's totally snug.
<img src="http://brotherson.com/cars/images/TransAm/asp/AUT_5116.jpg" alt=" - " />
<img src="http://brotherson.com/cars/images/TransAm/asp/AUT_5117.jpg" alt=" - " />
Is that right or ok? Should I be trying to get more of it snug? I about herniated myself and it won't turn anymore.
DaveK Apr 24, 2003 04:17 PM
Re: ASP install-can't be right?(PICS)
don't force it on any further-remove it and see what's wrong-it may have gone on crooked. clean up the crank snout and try again.
CySevans Apr 24, 2003 04:20 PM
Did you grease the crankshaft and the inside of the pulley? And hopefully you used the old bolt to press it back on. You should also put some grease on the underside of the bolt head.
It does not look seated all the way. You should torque it to 240 ft lbs, then back it off and install the new bolt. If you can't get leverage to get it pressed on, get someone bigger than you. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ramrrr02 Apr 24, 2003 07:40 PM
i can not get he stock one off. the crank keeps spining on me.
Black Sunshine/ 00SS Apr 24, 2003 10:25 PM
"i can not get he stock one off. the crank keeps spining on me." Have a friend keep the flywheen from moving, problem solved.
I can't see too clear from the pick. The quick way to tell is to see if your other pullies line up with the ASP.
Did you recently put on a double timing chain? If so, please read my post from last week. Good luck.
Constrictor 98TA Apr 25, 2003 10:19 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black Sunshine/ 00SS:
<strong> "i can not get he stock one off. the crank keeps spining on me." Have a friend keep the flywheen from moving, problem solved.
Did you recently put on a double timing chain? If so, please read my post from last week. Good luck. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmm, Im curious if he put on a double timing chain....if so, was it the Rollmaster. I have both a Rollmaster timing chain and an ASP pulley and this part of the install has me seriously stressed out. I hope I dont run into any of these problems.
And to Black Sunshine...I did a search in all of External Engine by your user number "409" for the words "timing chain", "ASP", "pulley" and found nothing. Do you remember the name of the post you are talking about?
Nevermind, I found the post, it was in Internal Engine...
<small>[ April 25, 2003, 10:26 AM: Message edited by: Constrictor 98TA ]</small>
horist May 2, 2003 10:51 AM
TTT
Mine kinda looks like this too... I have a rollermaster double chain, and had my pulley machined. PUlley lines up fine, just wanna make sure this wont cause a prob w/the front seal...
boos2 May 2, 2003 04:23 PM
I thought you didn't have to machine the pulley with a dbl roller set on the f-body. I thought that was only on the vette.
Zeta May 2, 2003 04:35 PM
I looked at mine Wednesday, and yours looks familar.
Install the belt, it will show by how much the pully needs to move.
What the heck is the stuff towards the passenger side of the car? It looks grey and rough?
Roadrunner 45 May 3, 2003 11:34 AM
This may be a stupid suggestion as I haven't done an aftermarket pulley swap, but I'd start by making sure the new pulley is on straight (tune engine over by HAND and take measurements from the flange to a fixed point). If it appears to be straight, I'd pull it off and measure the bore on the old pully and compare it to the bore on the new pulley, then measure the crank snout diameter. It is possible you have some tolerance stack up- if the crank snout is on the high, and the new pulley was machined to the low (or is undersize from the manufacturer) you'd have a problem. I'd call the pulley manufacturer for help and give him the #'s. A difference of as little as .0005" to .001" on the bore of the pulley can make a HUGE difference in how it fits on the crank.
needmoremoney May 4, 2003 10:23 AM
I just installed my ASP pulley, and I looks EXACTLY as his does. So Whats the answer to this? IS it OK, If it goes on anymore, the pulleys wont aline correctly.
needmoremoney May 4, 2003 12:34 PM
anyone?
needmoremoney May 4, 2003 08:25 PM
anyone to reply? I would like to know the answer to this aswell, so when I start my car up, I dont have OIL pissing everywhere. :cry: :bang:
StevieZ May 4, 2003 08:32 PM
I have heard that people using the SLP double roller have had clearance issues. I have the Rollmaster double and no machining was required.
needmoremoney May 5, 2003 07:58 PM
OK, so buy looking at his pics, is the pully on correctly or not? If not, how do I fix mine?
mattbta May 6, 2003 12:36 AM
Sorry I haven't responded....been out of town and finals this week too! I couldn't get the bolt any tighter. When I went to back it out to put the new bolt in, it wouldn't budge. (oh crap) Had to take some pipe and put it over my breaker bar for more leverage. Got it out and this is what it looked like...
http://brotherson.com/cars/images/cr...t/AUT_5311.jpg
http://brotherson.com/cars/images/cr...t/AUT_5312.jpg
http://brotherson.com/cars/images/cr...t/AUT_5313.jpg
Something doesn't appear to be right. Maybe I wasn't getting enough threads on it when it started and it stripped. Sucked all the bolt fragments out with a magnet and debated for a while...decided to go ahead and try and put the new bolt in. Threaded in ok, then started getting tough. Ought oh....maybe this one was stripping too. It actually was giving more and we were able to get the pulley snugged up much closer than that of the above pics. I's say there's less than an eigth of an inch of that silver part showing now. Bolt wouldn't budge anymore and it was bending our breaker bar. Decided it looked pretty good, so I put the belt on it. Took it for a few spins and all is well. Won't test it on highway to see if it tosses a belt until tomorrow...was too late tonight and didn't want to have to drive 20 miles to 24hr autozone if it did.
Sorry so winded....hth.
-Matt
mattbta May 6, 2003 12:39 AM
That's what happens when a thrown belt gets stuck on some ac pulleys....those things are FRIED!!! Wonder how much they are from dealer? Crap...
needmoremoney May 6, 2003 07:51 AM
OK, But mine looks the same as your did? Am I ok, the pulleys line up perfect. I impacted mine on and used red locktite, so she is stuck on there. And all you people are saying did we use a double timing chain, I DID NOT, IM USING STOCK CHAIN. Is this thing going to leak oil? Or is it just a simple thing, and im getting upset over nothing. (wont leak) :cry:
Zeta May 6, 2003 08:42 AM
If the belts line up ok, I would be ok with the location of the balancer.
I would not at all be happy knowing that I did not have the bolt properly torqued down. Installing the balancer using an impact wrench is a hack. Also the factory bolt has locktite like material on the bottom side of the bolt flange. Good luck doing any work, which requires removing the harmonic balancer.
needmoremoney May 6, 2003 09:11 AM
Thanks for the reply, So I wont leak oil from the front seal even thought the balancer isn't up to the seal, or those two have nothing to do with each other? The belts match up fine, and I put my torque wrench on there and got it up to 230 FT Lbs, and then it clicked. So everything is fine then?
I just dont understand why this ASP balancer dont go all the way up like the stock one did.
© 2026 MH Sub I, LLC dba Internet Brands
