LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   I Need A Y-pipe That Won't Scrape, Please Help! (https://ls1tech.com/forums/generation-iii-external-engine/536871-i-need-y-pipe-wont-scrape-please-help.html)
Xtreme57 Jul 6, 2006 01:44 AM
1 Attachment(s)
So I just got my new eibach pro-kit, bilstein revalves, panhard bar, and relocation brackets put on my car. I have Pacesetter LTs, a TSP catted y-pipe, and a GMMG cat back. I have approximately 2" of ground clearance under my car.
I drive into the city for work, so this just won't do. Now if I could find a shop to fab up a y-pipe like the one in the attached pic, I'd be set. I just have NO IDEA where to look.
Can I get the parts myself and do it that way?
Anyone know a shop in the northeast area that can do this?
Anyone know a shop that HAS done this that I could just order it from?
Or should I just go w/o the cats and use an ory to solve the ish?
I need some help here guys, and fast. Anyone with experience on this subject PLEASE chime in
Thanks
Xtreme57 Jul 6, 2006 02:08 AM
So i've been doing some research, and if i get the parts together I can maybe just bring the stuff to a shop and have them fab the rest. Here's my next question ...
If my Pacesetters are 3" outlet (like the pic), do I go with cats that also have a 3" inlet/outlet or should they be 2.5"? I always forget how the sizing works w/exhaust piping ...
Also I need a merge collector as the pic above shows ... the thread it came from(https://ls1tech.com/forums/showpost....76&postcount=4) says a 4" merge, but does that mean 3" inlet (from the y) and 4" out (to the cat back?) or since my GMMG is 3", should I get the 3.5" outlet or just 3" .... i'm so confused..
do i get the same size piping or different ... ??? I always forget how to figure that stuff out ... help!
Demon Of Dreams Jul 6, 2006 09:17 AM
get the same size and use straps or if you want it one piece, have it welded...
as long as you're running cats, any shop will take on the project, but its up to you to get some dimensions for them and tell them how snug up you want everything...
you could, however, use some oval tubing, and though it is a BITCH to get bent for your usage, you can run a larger diameter and still gain some clearance... oval pipes with round inserts to mate up with everything is really nice (some places also make oval inlet cats/mufflers, rare but they're out there)
Xtreme57 Jul 6, 2006 11:16 AM
hmmm i hope my guy at midas is up for a challenge
ryanfx Jul 6, 2006 11:43 AM
could you take some pictures underneath the car? where is the lowest point of ground clearance? Driver side floor board?
Xtreme57 Jul 6, 2006 12:22 PM
I don't have my digital camera right now, but yup, driver's side from the cat to the cat back. Any suggestions?
© 2026 MH Sub I, LLC dba Internet Brands
