What do i torque the headers to?
Old Aug 5, 2006 | 06:04 PM
99camarosupersport's Avatar
Default What do i torque the headers to?
Have an exhaust leak on the driver side bank so i bought a pair of felpro gaskets to replace the paper gaskets that came with the hookers. Is there any specific torque limits to what the headers bolt up to the heads at? Any input will be appreciated ..... thanks.
-Kyle
Old Aug 5, 2006 | 06:10 PM
RrCoX22's Avatar
out of ls1howto.com just did mine today
Exhaust Manifold Bolts (First Pass) 11 lb ft
Exhaust Manifold Bolts (Final Pass) 18 lb ft
Start from the middle and uniforming to the ends
Old Aug 5, 2006 | 06:15 PM
I looked on ls1howto.com and couldn't find anything. thanks alot!!
Old Aug 5, 2006 | 06:56 PM
INMY01TA's Avatar
Should have used stock gaskets. No leaks.
Old Aug 5, 2006 | 09:16 PM
yea i know but i'm a pos
Old Aug 6, 2006 | 12:47 AM
RrCoX22's Avatar
yes you are
Old Aug 6, 2006 | 12:54 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
tq specs are for suckers when it comes to headers. I used my built in one.
Old Aug 6, 2006 | 02:24 AM
Originally Posted by RrCoX22
yes you are
ah man
Old Aug 6, 2006 | 02:44 AM
Speed Density's Avatar
hashtagBMW
Yea man,
Just get em good n tight and run with it, if it sounds leaky do a little more, your internal TQ settings should do the trick.
Tony.
Old Aug 6, 2006 | 05:48 AM
BlackBADaSS02's Avatar
Glad this was posted. I'm putting my longtubes on today.
Old Sep 8, 2006 | 02:58 AM
Mikkofin's Avatar
Just for search purposes. Engine torque specs are found www.ls1howto.com
Old Sep 8, 2006 | 07:32 AM
rufretic's Avatar
I don't like leaks so I go with 30ft/lbs and stock gaskets, no leaks .
Old Sep 8, 2006 | 08:21 AM
Mr Incredible's Avatar
Use a tq wrench or suffer the fate of fools....Helicoils or worse.
