warrenty on cats? 80k miles?
Old 08-16-2006, 10:21 AM
onoiocoko's Avatar
Default warrenty on cats? 80k miles?
my car is getting close to 8o000 miles and the ses light is on and the code is the right rear o2 sensor so it is possibly the cat. i am going to get it scanned from the dealer because autozone scanned it first. can anyone verrify the warrenty on emissions? is it 80,000 miles? do u have to be original owner? thanks.
edit: car runs fine. i dont think gas milage is too bad. probably 260 a tank, mostly highway. i wouldn't think sensor would be covered.....
code: p0430 catalyst system is efficent on bank 2. below threshold for current engine operating conditions. so throw your 2 cents in.
Old 08-16-2006, 11:11 AM
Cakes's Avatar
I just had my passenger side cat replaced under warranty. My car at the time had 59K on it and I had no problems as its 80K for MAJOR emissions components. Call the dealer and have them set you up. Took (3) days total for the repair.
Old 08-16-2006, 11:13 AM
2000WS6TA's Avatar
its a 8 year 80k mile warranty on most emissions equipment i think. i had mine repalced for free.
Old 08-16-2006, 10:09 PM
Pontiacerator
RevGTO's Avatar
Right - same here. I just had my driver's side replaced. In at 9:00am, out at 3:00pm. Free. Do it before you turn over 80k!
Old 08-16-2006, 10:10 PM
onoiocoko's Avatar
sweeet. thanks.
Old 08-16-2006, 10:16 PM
LS1Aggie09's Avatar
yep....just confirming...i had mine changed at 79,500ish right after buying it...original owner wont matter because the feds reimburse the dealership since they require the cats
Old 08-17-2006, 05:05 AM
92SilverSHO's Avatar
im the second owner of my car and my cat failed like yours, same code. They might try to BS you saying its the o2, but you gotta call them on it. I had them drag a so call tech outside with a tech2 to make sure the o2s were working as they claimed, one wasnt.
Old 08-17-2006, 09:30 AM
onoiocoko's Avatar
thats good to know since i just dropped it off.... ill try to have them check it if they bs me. did ur cars run bad with clogged cats? mine i dont really notice unless it is just rpm surging from time to time, maybe after slowing down or something.
Old 08-17-2006, 10:18 AM
On the tree
Sneakyws6's Avatar
I memory serves me right the Federal Emissions warranty covers the ECM, and cats and exhaust for 80,000. I dont know for sure though if the o2's are covered or not. I would think they are since they are part of the emission system.
Only problem you might have with this is this. I had my cat replaced at around 35,000 for the same error. By 50,000 the other cat threw the code and the ECm measure the flow rate or efficiency for both cats and when one if higher or lower than the other it triggers this code. I had one done and asked about having both replaced and GM said no.
Sure enough 15,000 miles later the other cat showed up on the code. I asked again and GM said no, said screw it remoevd them and edited the codes out and now dont have them anymore.
Old 08-17-2006, 02:46 PM
LS1Aggie09's Avatar
car ran fine with the clogged cat...or so i thought, when i had the new one put on, i did a lid, flushed the injectors, and changed my fuel filter at the same time and noticed a difference...not a huge one but there was a noticeable difference in how smooth it ran
Old 08-17-2006, 10:02 PM
TooSlow02's Avatar
Federal Emissions Warranty covers PCM and Catalytic convertors only for 8 years or 80,000 miles, whichever comes first. Exhaust systems and all other emissions related equipment are only covered for the first 2 years or 24,000 miles, whichever comes first. California has extended coverage with additional components covered to 8/80, but only cars sold with California emissions are covered.
Old 06-04-2007, 10:32 AM
DarkhorSe_SS's Avatar
mine threw the code (passenger cat) last night and went by the dealer to confirm the warranty on the cats. I also have a oil leak somewhere so I got ext'd warranty through bank so I'll get that covered at the same time. It covers the gaskets as well on my ext'd warranty.
Old 06-04-2007, 12:08 PM
BurtReynolds's Avatar
I think they extended the warranty because I got a recall notice from GM.
Old 06-05-2007, 03:54 PM
Ripper415's Avatar
yeah, this was big news a few months ago when it came out. i dont remember the wording of the letter (or where mine is lol) but that thing SHOULD cover any cat problems you may have.
Old 06-05-2007, 04:04 PM
2001NBMZ28's Avatar
GM extended the cat warranty on the 00-02 cars to 10yrs/120K. http://img518.imageshack.us/img518/4605/gmletterle2.jpg
Old 06-07-2007, 11:26 AM
onoiocoko's Avatar
whoa. this was dug up from a while ago. got new cats for free so this did help. thanks.
