LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Vacuum line's purpose? (https://ls1tech.com/forums/generation-iii-external-engine/562229-vacuum-lines-purpose.html)
exSSer Aug 20, 2006 12:31 PM
Am I correct in assuming the small vacuum line that attaches at the rear of the intake manifold,(LS6 style) is the line that goes to the air pump? I've removed the pump and it's nest of snakes, but I'm wondering should I plug the line right at the intake manifold outlet? BTW, this is on a 'vette, but it's probably the same for f-bods.
BADFNZ Aug 20, 2006 01:08 PM
That vacuum line is for your HVAC controls. So if you want to use your vents for anything, I'd keep it.
RevGTO Aug 20, 2006 01:48 PM
There is a vacuum line for the AIR setup; if you removed your AIR and have an unattached vacuum line from it, you need to plug it. At least that's how it is for f-bods.
© 2026 MH Sub I, LLC dba Internet Brands
