LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   98 Knock Sensor's (https://ls1tech.com/forums/generation-iii-external-engine/563166-98-knock-sensors.html)
Luna Aug 21, 2006 09:19 PM
98 Knock Sensor's
Ok, I want to change out my knock sensors when I do my LS6 intake swap but I couldn't find a 100% sure yes this will work answer when I did a search.
I found these part numbers
Knock Sensors - 10456222
Sensor Harness - 12597415
Can anyone verify these are the correct part #'s to convert my knock sensors to the new style 99+?
Thanks!
gnomee Aug 21, 2006 09:21 PM
Why would you want to do that? Just for my own info.
Luna Aug 21, 2006 09:23 PM
The knock sensors on 98's are known to show false knock pretty much all the time. Basically they are just WAY too sensitive.
XtinctZ28 Aug 21, 2006 09:37 PM
For real? I dont think I have had any problems so far but that is an interesting bit of info.
gnomee Aug 21, 2006 09:39 PM
I just changed my intake to the LS6 on my 98. I have no issues that I know of. Is there something that I would notice without having it hooked to a scanner? This sounds familiar though, didn't they have the LT4 to replace the LT1. Think they would have got it right in the next gen motor.
Luna Aug 21, 2006 10:32 PM
No you wouldn't notice anything but a lack of power (which you probably would never notice because its always missing) without it being hooked to a scanner. I believe they always show knock retard even when there is not real source of knock. There was a GM Service bulletin about this issue. I just wish I could find more people that knew something about it.
A-Dub Aug 22, 2006 08:51 AM
The 98 sensors have a habit of failing.....and when they fail, they can read a constant 4 degrees of knock retard. This does not mean that 98 LS1s are constantly running with 4 degrees of retard. The timing is only pulled if the sensor is bad and in this case, the sensor failure usually does not set an SES.
V-10 Killer Aug 22, 2006 08:58 AM
I had the false knock on my '98 and bought two new sensors for it. I did buy the '98 style sensors though. It fixed my problem. I recently changed to a LS2 402 and needed the newer knock sensors. I'll see if I can find the numbers. I can sell you my two one-year old '98 sensors for $25 shipped if you want them.
Luna Aug 22, 2006 09:17 AM
Ok that is a little bit different than what I have read but makes sense.
Luna Aug 23, 2006 08:51 PM
Anyone else have some input ?? :confused: :confused: :confused:
© 2026 MH Sub I, LLC dba Internet Brands
