Gutted stock 2001 F-body MAF I'm running SD, but I need to maintain stock appearance, does anyone have a gutted and/or broken MAF they want to get rid of...? Please pm me. Thanks. :cheers: |
pm sent |
i may, ill have to look... if i do ill shoot you a pm |
not sure what u mean? |
Originally Posted by LightEmUpLs1 not sure what u mean? Speed Density, running MAF-less, getting airflow/airmass from VE table only; but I need a gutted MAF (no sensor element, no screen, but able to plug in MAF wire connector) to look stock for CA smog visual inspection. Thanks to all for replying. :cheers: |
Can you get a stock housing and run it that way? I just don't understand I guess. You aren't going to be plugged into the MAF sensor so does it matter if it looks non-SD? |
The car has to pass visual inspection meaning all the plugs and emmission control items need to be in place before the inspection is done. |
Originally Posted by orangeapeel Can you get a stock housing and run it that way? I just don't understand I guess. You aren't going to be plugged into the MAF sensor so does it matter if it looks non-SD? Yes, it does matter in CA :cry: , they check for presence of MAF sensor if car came with it. And the CHP has been pulling people over and looking under their hood, and a large hose will just look too inviting to them. |
Ahhh, I didnt know that it was an emissions thing. So you need to be visually pleasing and still be able to stay SD. I gotcha man. |
Interesting tidbit. :judge: |
Originally Posted by orangeapeel Ahhh, I didnt know that it was an emissions thing. So you need to be visually pleasing and still be able to stay SD. I gotcha man. |
Joe - MAF is on it's way. It is functional, but was a severly bastardized unit. It's an excellent candidate for a gutting. |
Originally Posted by TAQuickness Joe - MAF is on it's way. It is functional, but was a severly bastardized unit. It's an excellent candidate for a gutting. Thanks mate, I appreciate it, I'll have fun gutting it. What has been done to it...? Cheers Joe :cheers: |
descreened and butchered air foil. Just need need to remove the elements and smooth out the interior |
TA, I see it, 90% of the work has already been done. :cheers: Thanks, Joe :drive: |
© 2024 MH Sub I, LLC dba Internet Brands
