Can't get the alternator pulley off??? Does anyone have any tips to get the alternator pulley off? I was using a Torx 50 to keep the pulley from turning and a deep offset wrench on the nut itself. I pulled on the wrench so hard that it broke the torx bit in half. :bang: The nut never budged. I was told that it is reverse threaded. Is this correct? Now I have to remove the other half of the Torx bit from the front of the alternator. |
Use a air impact gun! |
That crossed my mind but how do you keep the pulley from turning when you put the impact on it? I thought about chucking it in a vise but that would most likely ruin the pulley. |
It's standard thread, not reversed. I used an impact on mine. I tapped the trigger a couple of times and it zipped right off. I ordered an overdrive pulley and have a 160 amp altenator. So I practiced on my og altenator to see how it came off. It did come off easy with the impact. I'm going to try the wrench/torx bit method when the pulley comes in. If I can't get it, I'll pull it to use the impact. |
On most alternators there is a little access port where you can stick something in, like an alan wrench, to jam the rotor. Check it out in the shop manual. |
Originally Posted by ShevrolayZ28 On most alternators there is a little access port where you can stick something in, like an alan wrench, to jam the rotor. Check it out in the shop manual. |
Well, judging from your post White Rhino, the only reason I broke my Torx bit is that I was trying to turn the nut the wrong way thinking it was reverse-threaded. I guess now mine is EXTRA tight. Looks like I have my work cut out for me!! |
| All times are GMT -5. The time now is 09:24 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
