LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Security Problem, Car won't Start. NEED HELP FAST! (https://ls1tech.com/forums/generation-iii-external-engine/568907-security-problem-car-wont-start-need-help-fast.html)
Cole Train Sep 1, 2006 02:25 PM
***FIXED***Security Problem, Car won't Start!
Ok i went out to my car today and started it and it started fine. Went down the block and noticed the security light flashing so i pulled over to shut it off and figured the key may have been off a little. Went to start it and NOTHING. It doesn't crank or anything. Just sits there and fuel pump primes and all but nothing. What's wrong with the damn thing? A fuse maybe. THanks guys. It's my daily driver and i need it fixed~Cole~
Fire-formula 93 Sep 1, 2006 03:09 PM
It is a security system called VATS. I dont know much about it but do a search and you can find how to bypass the system. It happens quite often.
The PAT WS6 Sep 1, 2006 07:43 PM
yea its the vats that needs to be over written u are going to have to have to search cus i honestly dont knw my self
good luick
SIC LSX Sep 1, 2006 09:36 PM
check you rchip on you key it should read some resistance! that's what was bad on my key and another thing to try is use your another key if it works the chip on you key is bad thats what happend to my car.
Cole Train Sep 1, 2006 10:14 PM
That's the bad thing is i don't have another set unfortunatley. I'll go fidget with it tonight. Thanks a TON guys. I appreciate the help with it.~Cole~
aaron653 Sep 1, 2006 11:50 PM
that happened to me one time and I tried to start it the next day and it started right up
785T/A Sep 2, 2006 12:26 AM
My buddy's camaro did that and we unhooked the battery for a few minutes then it started.
Cole Train Sep 2, 2006 01:27 AM
Well i looked into my manual to see what i should be looking for. I noticed that when i get in the security light is FLASHING not just staying on. In the manual it says it's the key is faulty. I'm gonna look more at it in the morning when it's light out to see what i can figure out.
Cole Train Sep 2, 2006 10:56 AM
well update. I looked at the fuses and all the basic stuff and nothing is out of the ordinary. Took the key up to a local dealership that my dad happens to work for :) and one of the techs said he is sure it's the tumbler. He had a newer Camaro SS in there for the same thing and the same symptoms. Changed the tumbler and keys and all was good. He priced a tumbler and new key for $90 and another $25 if i want him to put them in for me on the side. What is your guys' input? He couldn't look at the car because it's not there and i can't get it up there today 'cause it's raining. :bang: but he is almost positive that's what it is. ~Cole~
mike6681 Sep 3, 2006 11:16 AM
The price sounds exactly right on, I had an older Lumina 96 that had Vats and it did the exact same thing. I replaced the tumbler and got 2 new keys,
Cole Train Sep 4, 2006 12:19 AM
Well guys i got it fixed with the bypass. The car starts better then it did before too since i fixed it. Took me 20 minutes to do. Thanks for all the help~Cole~
orangeapeel Sep 4, 2006 12:55 AM
VATS = PITA
Don't ever put the wrong key in the ignition. That is a good way to lock it out.
Paul's_03SVT Sep 5, 2006 08:56 PM
what was the bypass?
© 2026 MH Sub I, LLC dba Internet Brands
