up to date pn's for coolant pipe and plugs
Old Sep 12, 2006 | 07:25 PM
SLEEK00SS's Avatar
Default up to date pn's for coolant pipe and plugs
I have searched the forum a couple times and I'm finding that there are so many different part numbers for the pipe and plugs that I need to install the LS6 manifold. Does anyone have the current GM part numbers that will work? Thank you.
Old Sep 12, 2006 | 11:49 PM
Gearhead1's Avatar
GM Coolant crossover pipe (P/N 12581213)
GM Coolant plug (P/N 12602540)
Old Sep 13, 2006 | 12:23 AM
Ferocity02's Avatar
Or you can get two of the front crossover tubes. You can then block off the rear one or run a 1/4" coolant hose from the back to the front to help the rear stay cool. This is what I did.
Old Sep 13, 2006 | 04:15 PM
SLEEK00SS's Avatar
thank you
Old Sep 13, 2006 | 08:26 PM
bad6as's Avatar
more info
Old Sep 20, 2006 | 04:59 PM
SLEEK00SS's Avatar
i just got my manifold today and it came as a kit with the pipe and plugs. the pipe part number i have is 11122789 for the pipe and the manifold number is 12573572. are these the correct numbers? just wanna make sure.
By Brett Foote | 2026-06-04 05:00:17
