Does anyone make a water pump stud kit?
Old Oct 20, 2006 | 08:34 PM
Hugger's Avatar
Default Does anyone make a water pump stud kit?
I am about to do cam swap #4. I get so tired of lining up the water pump and starting the bolts while holding up the pump. On the first swap I managed to damage one of the threads in the block and had to heli-coil it on cam swap #3. It would be so much easier if I had some studs for the water pump. Does anyone make them?
Josh
Old Oct 20, 2006 | 09:52 PM
1FSTZ71's Avatar
Josh
You could make your own stud kit. Call arp and give them your bolt sizes, then they can supply you with the proper studs and nuts/washers. I was going to make a head stud kit for my OHC straight 6 lol. Needed to do it all from scratch and ARP was very helpful in providing the right stuff.
Old Oct 21, 2006 | 12:14 AM
00454sscamaro's Avatar
thats a good idea, the water pump is alil tricky to line up. the gasket also if you dont silicone them to the pump.
Old Oct 21, 2006 | 03:47 PM
MiaSSmaro98's Avatar
why dont we help the original poster and then he can tell arp what he needs,and get a couple of pairs for us
