Little gap help on TR6's For a 402ci. 11:1 248/254 629/622 113 Patriot Stage 3 LS6 heads Runs on pump gas. Thanks in advance!!! |
If no nitrous then .050 |
Nope. All motor. Thanks!! I thought maybe a little smaller than that, but I could easily be wrong. |
LSX are not gap dependent. You could run .045 with no ill effects. We reduce gap to prevent spark blowout as compression rises or nitrous or both. |
For that motor... TR6 or TR55??? I was going to try the TR6 and see how it goes. Compression isn't much more than stock, but I was thinking a touch cooler plug might not be a bad idea. |
moving to external... |
I'm running TR6s at .045 and they are burning very clean and healthy. 408 with a 248/252 11.6:1 compression pump gas motor here also. I hope this helps. |
Tr6 @ .040 - .045 |
Thanks guys!! I will try .045" and go from there. |
I've got a 383 11.6:1. Just switched from TR55's (.050) to TR6's (.040). Cured a few random KR issues I was having. |
| All times are GMT -5. The time now is 05:44 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
