Loudmouth II Question
Install the Loudmouth II in the I-pipe then get a muffler shop to cut out your stock muffler and weld in a piece of straight pipe where the muffler used to go and a Tee to split off to the right side tail pipe. Or just run the one tailpipe.
LM II = $100.
Welding..../pipe ...< $100.
You get the LMII sound/power for $200 not $400.
Note: The LMII is 3" diameter. Measure the stock I pipe to see if it is 3" as well.
You'll have the sound and similar HP to the LM but will always be able to cap it in case it gets annoying.
