How far did you grind down your K-member for headers?
I was grinding down the k-member on a friends car on Sat and I was starting to go through the metal. I didn't really like this so I stopped. It's now banging the k in stead of resting on it like it was. I was wonder how many of you have gone through the k opening up a hole? Is this safe to do?
the headers in question are QTP headers. which everyone knows has a clearance issue with the passenger side header resting or banging on the k-member.
found this, someone else just cut a square out of the kmember.
Originally Posted by radz282003
I ended up cutting out about a 1.5" X 1.5" square where the #2 primary passes over the k-member. Then I spent a good about of time grinding it to a form similar to the primary shape for adequate clearance. Cleaned it up, primed itshot it black. Done. No problem.
I had to grind down the K-member a little for my Jet-Hots to fit right. It was on the driver's side right where one of the primaries comes close to the K-member. I didn't have to grind much though, maybe 0.125".
