pcv question do i have to run a breather on the valve cover if i dont have pcv. can i just put another oil cap on the otherside or will the pressure build to much? |
You need to have a breather on one side. If you dont have a breather or pvc youll blow oil out the seals or past the rings. |
so i can seal up one side aslong as i have a breather on the other? |
© 2024 MH Sub I, LLC dba Internet Brands
