LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   ORY Q's (https://ls1tech.com/forums/generation-iii-external-engine/619390-ory-qs.html)
LS1Silverado05 Dec 5, 2006 12:50 PM
ORY Q's
Is there a company that makes an ORY that will bolt up to factory manifolds? On our 99 WS6 we lost the drivers bank of the engine, witch loaded it up with fuel and toasted the cat. So we need to replace the Y-Pipe and there is no way we are putting cats back on. However there arent any funds for LTs at this point, so we need to find an ORY that we can bolt up to the factory manifolds. Do you just order one for shorties?...Or is there a seperate kind? Also, will the car be able to run and drive ok for a couple weeks without a tune after we put in the ORY? Will it just have the Engine light? I just dont want to do any damage. Thanks guys.
Tainted Dec 5, 2006 03:15 PM
borla and slp make one
lsx24 Dec 6, 2006 11:04 AM
You should be fine until you get a tune, or even without because most of the time a change like this will expose a rich-running car...you're going to be smelling a lot of gas, but should be safe to the engine as alot of people do it without getting a tune.
LS1Silverado05 Dec 6, 2006 02:46 PM
The SLP and Borla Units act as though they only replace the crushed oval section of the factory Y. The SLP one even says, attaches to the factory Cats and Exhaust Pipe.... What we need is a replacement that will run from the Factory Manifolds...all the way to where it can mate to the cat-back.
pSSycotic Dec 6, 2006 03:43 PM
I have a custom one from when i had my stock manifolds. Ill get some pics and sell it if ya want. It was a kooks, but the fitment was horrible. My buddy that works for TNT (they build badass vipers) cut it and fit really well
slimcracka Dec 6, 2006 06:35 PM
i have a stainless works ory for manifolds on my car now (which im about to pull off and sell for LT and ORY) but its made of stainless and is very very nice..ive had no problems out of it..and looks great too..
LS1Silverado05 Dec 6, 2006 11:01 PM
pssycotic & slim ... PMs sent. Thanks
LS1Silverado05 Dec 6, 2006 11:13 PM
Nobody makes a "cheap" one of these that arent stainless??
© 2026 MH Sub I, LLC dba Internet Brands
