Muffelx Y-pipe bump stop??
Old Dec 21, 2006 | 01:24 PM
Lawnboy's Avatar
Restricted User
Default Muffelx Y-pipe bump stop??
Thunder racing sells a 3" and 4" mufflex y-pipe bump STOP.
It clamps around the Y-pipe and mounts to the origaial floor board exhaust mount.
is any one using this? how well does it work, did it stop your Y-pipe from hitting the floor,
I have FLP long tubes and Y-pipe.
please let me know
thank you
Old Dec 21, 2006 | 01:28 PM
nexvctm2001ss's Avatar
Don't know but my mufflex ORY is being installed tell ya when I get it back and yes it has the 4" collector
Old Dec 21, 2006 | 06:26 PM
01Trans Am WS6's Avatar
It worked for me.
Old Dec 21, 2006 | 08:36 PM
BayAreaSS's Avatar
I did a search on this last week and it seems to work pretty good. A lot of people also bought poly motor mounts and it stopped the y-pipe banging.
Old Dec 21, 2006 | 09:50 PM
Lawnboy's Avatar
Restricted User
OK
i just ordered the 2.5" Y-pipe mufflex hanger Y-pine bump stop
from Thunder racing , they told me it should cure my problem,
I might do Poly motor mounts when i do my 346 rebuild
Old Dec 22, 2006 | 05:11 AM
2001WS6Vert's Avatar
When I modified my "Y" with a 3" to 4" merge I had to split the pipe. Before welding it I adjusted the drivers side down maybe 1.5" or so. That solved the problem (700rwhp and stock mounts).
Old Dec 23, 2006 | 09:30 PM
Jeremiah's Avatar
I left all the clamps loose and wedged a 2/4 between the tight side and put and jacked up the side with plenty of clearance and twisted the Y pipe. I tightened all the clamps back while there was still tension on the pipes and never had any issues after that.
