is it hard to swap an intake??
very easy, shouldnt take longer than an hour or 2. Just be careful when pulling the intake off to not break the oil pressure sending unit that's right behind it
Originally Posted by mvvette97
the oil pressure sensor is behind it or under it?
...if you can do a cam swap, there's nothing on the car you shouldn't be able to handle
Yeah, what they said. You did the cam... you can do the intake. No problem. Just take your time, and if you get to a point where you aren't sure take a step back for a sec before you continue.
If you're really nervous, print up the directions, and have them next to you while you do the work. Step by step is pretty easy to get right the first time.
GL!!
GL!!
I replaced mine a few weeks ago and it was easier than I thought. Just take your time and my mindfull of the hoses on the rear of the intake. Once the new intake is installed, thread all of the bolts before tightening.
http://www.ls1howto.com/index.php?article=5
your best friend is a air compressor with adjustable rachet for the rear intake bolts....leave the bolts in but pull them up and put tape between where the head of the bolt is and the manifold itself....this will keep them from dragging on the valley cover and also makes it easier then reinstalling the bolts....becareful not to push to hard when trying to put the manifold back in, it will have a tendacy to get stuck and the push might smack the psi sending unit in the back....a fuel line release tool is a must, and becareful not to knock anything down into the valves....trust me when you take the manifold off its going to be very dirty under there
If you are swapping the intake you will at some point need to swap the fuel rail & injectors from the old intake to the new. After now doing both an intake swap and just swapping injectors I'd say that is doesn't really matter either way. You will need to pull the injectors out of the intake and wheter or not you disconnect the fuel line fitting is up to you. If you disconnect it you can work a bit more comfortably at a bench or just flip it out of the way, install new intake and re-install injectors and rail.
I must say that even with the PLASTIC fuel removal tool that thing can be a bitch. I swear that is a secret to using that tool to it's fullest potential because the first time it took almost an hour to separate the line from the rail.
If you do separate it take a couple plastic bags and a rubberband and seal off the line and zip-tie it out of the way. Keeps any unecessary gas from spilling out.
i pulled the injectors out along with the rail and moved them aside. i didn't see the need for removing the line since i have to pull them out anyway.
That's what she said...
well I got it done. I can't feel any differance between the stock and the stock ported manifold. Oh well, now I know how to do it. Thanks for all the help.
