Oil drain Bolt and FLP Headers - will it come out? Pic Inc
Old 01-07-2007, 05:08 PM
solocus's Avatar
Default Oil drain Bolt and FLP Headers - will it come out? Pic Inc
Do you all think this bolt will come out with a little prying on the header or will I have to grind the bolt head?
Yes I know the underside of my sons car is dirty and there is apparently an oil leak as well.
Old 01-07-2007, 05:18 PM
Dex
Dex's Avatar
It should come out the threads aren't that long. Good luck not burning yourself if it how.
Old 01-07-2007, 05:24 PM
CHRIZ28's Avatar
Looks like it might. Might be worth the lost oil to try it now while you're working on the car. But I bet it will.
Chris
Old 01-07-2007, 05:53 PM
flyin red TA's Avatar
I doubt it will come out without prying. That gap between the header and the bolt is about half as long as the bolt actually is.
Old 01-07-2007, 06:28 PM
solocus's Avatar
I expect that with some prying it will come out. While doing a search here most say it will but otheres do grind the head of the bolt down a bit. I was hopeing someone would have the same situation and tell me for sure.
Old 01-07-2007, 06:45 PM
jimmypop13's Avatar
My FLPs are close like that too and I've never had a problem getting the bolt out. It's not threaded all the way down
Old 01-07-2007, 07:16 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Mine come pretty close, but the plug comes out easily.
