LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   How do you test Coil's? LS1 miss (https://ls1tech.com/forums/generation-iii-external-engine/643776-how-do-you-test-coils-ls1-miss.html)
Arkangel77 Jan 19, 2007 09:17 PM
I have searched a bit - I guess I just did not look under the right heading. Can anyone tell me how or send me to a link that explains how to test a coil? I have a miss in my 99 ls1 & I am almost positive its a bad coil. I dont want to just start guessing and swapping so if you can Help PLZ post some info. Thanks - Arkangel77
Da Swami Jan 20, 2007 12:14 AM
Well, you could do a firing voltage test on the wires......under the assumption that a malfunctioning coil would not be putting enough voltage through to the plug.
Z28_DAD Jan 20, 2007 10:03 AM
do you know what cylinder is missing? if so, what i do is swap one componant to another cylinder, one to a different one, etc.
example-missfire is on #4. put the coil to #2, wire to #6, and plug to #8. see where the miss goes. if it goes to #2, its the coil. if it goes to #6, its the wire. if it goes to #8, its the plug.
truglow Jan 20, 2007 11:23 AM
I had the same problem.I took a chance and purchased a cheap code reader ($75 walmart).It narrowed down the cyl, then you check the coil ,wire and plug.The coil can be checked by resistance.Do a search on the specs it will come up.
Arkangel77 Jan 20, 2007 07:01 PM
I looked for the resistance = thats the info I am trying to get. I wana know what resisteance it should be that way I can just check them all and figure it out that way- I dont know which coil it is. Thanks, FGuys, Lata, Arkangel77
© 2026 MH Sub I, LLC dba Internet Brands
