LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   o2's disconected (https://ls1tech.com/forums/generation-iii-external-engine/670279-o2s-disconected.html)
Thule Mar 5, 2007 10:49 AM
o2's disconected
when i was installing my slp LM i noticed that the o2 sensor where disconected, still the car runs sweet, good idle, and went low 13's on it bone stock,
m6 car,
could anybody here know some reasons for this? is this some kind of a mod?
my Bmw runs like shit if i disconect the o2's but the camaro seems like not notice it at all, i did not conect them to "se what happend"
Brian2006 Mar 5, 2007 12:04 PM
both o2 sensors or just one? The previous owner may have deleted them
Danny2tek Mar 5, 2007 12:06 PM
Precat or postcat O2? If there postcat its ok.
TheBlurLS1 Mar 5, 2007 01:28 PM
:werd:
These cars have 4 O2 sensors. The rear O2's could be on Mt. Vesuvius and it wouldn't make a difference, you'd just have an SES light in your face (unless the rears were tuned out).
98Camarod Mar 5, 2007 01:49 PM
Or if there are 02 sims hooked up, its ok too.
SSpdDmon Mar 5, 2007 01:54 PM
These cars can run without O2 sensors. My '01 SS is setup to do this. If your car isn't set up for it, I wouldn't recommend it. But, it's not going to be fatal. Without feedback from the O2's, the PCM is running in an open-loop state. It commands an AFR based on a few tables and there's no telling how far off it really is. With only 1 or 2 bolt-ons (lid/catback), you'll most likely be ok. Much more than that and it'll start to get too lean. I'd make sure the front O2's are hooked up or get hooked back up. It'll save you some money at the pump and you won't run the risk of going too lean...until you start throwing more mods at it that is. :)
Thule Mar 6, 2007 04:38 AM
these are the rear ones, they are in the exhaust but not connected,
the cars dosn't run lean, and i dont seems like notice it at alls,
thats why i was wondering if there has bin done some modifications to maybe the ecu..
LS69TA Mar 6, 2007 05:53 AM
Yea, they have probably been turned off in the pcm. You'd have a SES light showing that they weren't working if they had just been unplugged without o2 sims.
RedWS6 00 Mar 6, 2007 06:21 AM
The rear O2's can be turned off, and if running on OL all the time, you could run without front O2's too if you really wanted.
I run OL-MAF tune. So no readings from the O2's are used in the PCM, also have no cats.
Thule Mar 6, 2007 08:52 AM
i am goin to take the cats off it, and install Y-pipe and LT's does the frons sensor still read rigth?
LS69TA Mar 6, 2007 08:54 AM
Yea the fronts will still read right. The headers should come with extensions for the o2 sensors.
RedWS6 00 Mar 6, 2007 09:09 AM
Yep your front sensors wont effected in respect to removing cats, as the front sensors are before cats anyway. But you may get erorr codes coming up, sometihng along the line 'Heated O2's failed'
With LT's your O2's will be further downstream, and wont get as hot, they will still work fine, (well mine did) but you will see that error code eventually.
© 2026 MH Sub I, LLC dba Internet Brands
