Need Help: Horn won't stop blowing Today I used my key fob to open my car as usual (horn set to blow when unlocked) and the horn started blowing. At first it was on off than solid on. I put the key in the ignition and it stopped for a minute and then started again. I removed the fuse and all seems well except of course the horn does not work. I disconnected the motion sensor near the spare tire but that did not correct the problem. I was thinking maybe the horn relay is sticking. Anyone know where the relay is located? Thanks-Craig <small>[ April 23, 2002, 05:04 PM: Message edited by: Craig98WS6 ]</small> |
Re: Need Help: Horn won't stop blowing Sounds like a freaked out alarm system... This is a good one for the electronics section.. https://ls1tech.com/ubb/cgi-bin/ulti...c;f=3;t=001334 <small>[ April 23, 2002, 05:32 PM: Message edited by: WILWAXU ]</small> |
| All times are GMT -5. The time now is 01:50 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
