Does this sounds like a good setup? I am going to get either QTP or Pacesetter Heards ceramic coated, slp cats, electric cutouts after headers, custom x pipe, slp LM 1, side exit with Z28 Tips. Let me know what ya'll think about my future setup. I hope to get some of it done this weekend. |
The x-pipe is good as long as you're not planning on getting lowered. Here's a link to a guy who got his pipes flattened to make for better ground clearance. https://ls1tech.com/forums/generation-iii-external-engine/333009-ws6-true-duals-pics-after-axle-mufflers-ceramic-xpipe-re-posted.html Make sure you have good flanges on those headers. I've often wondered if it'd be worth it to get cheap headers and put better flanges on them. It's probably up to a 2hp loss over the expensive headers. Just make sure you tune your length. (shorties for high rpm hp and long tubes for low rpm torque) |
Sounds like either a cheap or expensive setup. Get a boomtube setup. That sounds like the way you are wanting to go. |
Get a boomtube setup. That sounds like the way you are wanting to go. What is boomtube? |
© 2024 MH Sub I, LLC dba Internet Brands
