Radiator Hose Leaking! I going to the track for the first time tomorrow and I just noticed a leak coming from the hose that connects to middle underside of that big radiator pipe that runs right in front of the engine. It looks like the leak is coming right from where the hose connects to it. The hose looks fine could it be clogged, or just a bad connection? Also can I take this hose of without radiator fluid going everywhere? |
hose generally wear out from the inside out....no....and yes you should take it off and inspect the inside of the hose.... |
© 2024 MH Sub I, LLC dba Internet Brands
