hay guys i have a Granatelli LS6 MAF! can i port it?
1 Post
hi guys i have the ls6 MAF and this maf still has those two little things inside like the stock one kinda blocking the air flow, but this maf is plastic not like the stock aluminum one and this one isent seperatable so its harder to cut that restriction without damaging the wires, so i wanna know has anybody done this before? do you guys think i could do this without damaging something? thanks guys
Kleeborp the Moderator™
If your car is working well with something other than the stock 75mm unit, consider yourself lucky, and leave well enough alone. The MAF sensors on these cars don't take kindly to being messed with (actually, the PCM doesn't take kindly to it since the calibration will no longer be accurate).
1 Post
ok man i take your word for it, thanks, yea i got my car with that maf sensor i also have the stock one as well too. but thanks for everything, good thing i dident touch it.
