LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   100% custom built LT's.............. (https://ls1tech.com/forums/generation-iii-external-engine/747607-100-custom-built-lts.html)
Quickin Jul 11, 2007 11:42 PM
Who does this and how much would that cost?
1 7/8" stepped to 2"
I see that ground clearance can be quite a bit better than all the LT's out there if they were angled better. I want them since my car will reamin lowered as is.
Anyone?
5 LS1 7 Jul 12, 2007 08:46 AM
Contact Nick at American Racing Headers...they'll do anything u need.
silver-mod-o Jul 12, 2007 09:26 AM
Kooks will also build you a custom setup...
DONAIMIAN Jul 12, 2007 09:32 AM
Kooks already makes a 1-7/8 stepped to 2inch headers. I wouldnt go with anything custom for the sole purpose of fitting closer to the floor unless you had solid motor mounts to stop them from hitting when the motor tq'ed over.
jmm98LS1 Jul 12, 2007 09:36 AM
You're looking at ~$1500 for a custom set of headers, and they'll probably need your car for at least a week.
1997bird Jul 12, 2007 09:53 AM
This company can build you some very nice top end header's. They build alot of the top end race teams exhaust systems. The owner has done alot of research on header design with different firing order's. My cam grinder knows the owner and informed me that the "LS1" firing order tends to like the tri-y headers. http://www.burnsstainless.com/
silver-mod-o Jul 12, 2007 10:32 AM
I already knew they built 1-7/8 to 2 steps but I was just throwing it out there if he insisted on having something built solely or his use and his particular car. :)
DONAIMIAN Jul 12, 2007 11:18 AM
I figured you did, it was more directed at quicken tho :)
Quickin Jul 12, 2007 05:28 PM
Whatever it takes. It looks like there's alot of room all around both collectors to keep them a good 1 1/2" further off the ground. Is there any negative in using those solid mounts? It seems there's always a cure to a problem in this world, but than you have to give up your left nut.
Quickin Jul 12, 2007 05:29 PM
My car is lowered and I want to keep it that way. So custom is what I need, if I can really save some room off the ground.
My 1 7/8" Grots are pretty beat to shit, both sides. Couple little spots almost worn through.
© 2026 MH Sub I, LLC dba Internet Brands
