LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Difference between Catback and TD's... (https://ls1tech.com/forums/generation-iii-external-engine/748057-difference-between-catback-tds.html)
71-Camaro-98 Jul 12, 2007 07:40 PM
What is the difference in horsepower gain depending on if you go with an aftermarket catback vs. TD's?? And, which do you think is better?
JohnnyC Jul 12, 2007 07:44 PM
true duals sound and perform better than catbacks, but are also more difficult to install. Most of the catbacks will still flow enough to make big power, and sound O.K.
Trev_SS Jul 12, 2007 11:45 PM
most catbacks will sound good but you will never get rid of the rasp with a y-pipe like you will with duals, i have had both catback with ory and longtubes. know i have duals with moroso spiral flows and love the way it sounds
71-Camaro-98 Jul 13, 2007 03:32 AM
Yeah I always did like the sound of TD's better but my main question is how much horsepower gain do you get from an aftermarket catback and how much from aftermarket true duals... If there is a difference at all.
chadtx01 Jul 13, 2007 03:55 AM
Depends on what kind of catback it is and what kind of setup you have. You can still get the big HP numbers through a regular catback, and unless you're really moving a shitload of air you wont really need the TD's.
They do sound better though, I love mine.
95 Z28 Jul 13, 2007 03:58 AM
Not sure how much you're going to gain going from a stock exhaust to aftermarket (Y or duals) but most say that duals really outshine a y pipe setup in the midrange. My car feels stronger all around with my duals. I used to have a ORY/Borla exhaust.
Blu99T/A Jul 13, 2007 08:45 AM
Go with TD's and never look back. I get so many compliments with mine. The sound is worth it alone. I got my headers/duals setup for just a bit more than my old catback setup.
1FSTLS1 Jul 13, 2007 09:07 AM
Whats the average cost on true duals for someone to install themself who allready has Long Tubes?
mrr23 Jul 13, 2007 07:18 PM
here's a dyno from my wife's car. took off the borla 3" adjustable catback and bassani y-pipe and put the bassani tru-duals on. stock PCM.
http://www.stealthram.com/familypics...avsbassani.jpg
© 2026 MH Sub I, LLC dba Internet Brands
