backfire???
Old Jul 23, 2007 | 01:06 AM
Blknight6989's Avatar
Default backfire???
So after i just put on LT's and an ORY my cars been backfireing at low rpm every once in a while. This normal?? an please tell me it will go away!!!
Old Jul 23, 2007 | 07:20 AM
brad8266's Avatar
check for a cranked spark plug, when I did my headers the first time I cracked the ceramic on a plug and it ran like ***.
Old Jul 23, 2007 | 02:37 PM
Well im gonna do an oil change soon so i think i will jsut replace all my plugs with TR55's. Probably a good idea no??
Old Jul 23, 2007 | 04:19 PM
slaptastic's Avatar
NGK TR55's are a good choice. They were recommended to me. And you might have an exhaust leak. That's what was causing my backfire when I installed my LT's. Check to see if all your nuts and bolts are tight and that everything is sealed up tight.
Old Jul 23, 2007 | 04:21 PM
matt3383's Avatar
is it backfiring at idle or on decelaration? Mine does when if i downshift to slow down or let out of a gear... but not at low rpms
Old Jul 23, 2007 | 04:32 PM
skifast87's Avatar
My car does it if i do not let it warm up for moment or two before i drive it. It sounds to me however that you may have a cracked plug. Look them all over and change them if you want that should fix the problem you are describing. Let us know what you find
