LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Won't Idle (https://ls1tech.com/forums/generation-iii-external-engine/757666-wont-idle.html)
blueeyeddevil141 Jul 29, 2007 12:17 AM
Won't Idle
I have a '98 WS6 with open headers, and my stock stall won't lock up always...so my car will idle fine on start up, but after i drive it, at lights and stuff it will idle at like 400 and want to stall. What's wrong with it?
I have been running open headers for 2 months and never had this problem until 2 days ago.
staringback05 Jul 29, 2007 10:15 AM
you've probably finally burnt the o2s out....at start up and running your not using them as much....but when you come to stops they are switching back and forth pretty fast, you have techincally a HUGE exhaust leak right off the collector...any leak with in 9-12 inchs of a o2 will be picked up....
blueeyeddevil141 Jul 29, 2007 10:40 AM
Thank you! I have a set of handmade truduals which I am installing wednesday, so that should fix it I guess. Should I replace my o2's?
© 2026 MH Sub I, LLC dba Internet Brands
