98 Tcs??
Old Sep 7, 2007 | 05:38 PM
BlackTBird's Avatar
Default 98 Tcs??
my 98 t/a doesnt have a switch to turn off traction control. instead theres a little opening. i tried looking for tcs. the slp module tcs that reverses is only for 99 and up. any body else have the same issue?? pleasee help
Old Sep 7, 2007 | 05:45 PM
BeemerZ28's Avatar
well besides the fact that you probably dont have traction control. The system has an ASR button in the Firebirds. The button if you have traction control would be by down by the shifter. Where as the camaros have it above the radio.
Old Sep 7, 2007 | 05:51 PM
BlackTBird's Avatar
i have traction control. there is no switch there by the shifter. i know this because eveytime i burn out or launch the light comes on.
Old Sep 7, 2007 | 05:53 PM
SSkillz's Avatar
Low traction light? I dont think you have tcs....its just a light that comes on saying you have low traction.
Old Sep 7, 2007 | 06:03 PM
2001NBMZ28's Avatar
ASR/TCS cars have RPO code NW9.
Old Sep 7, 2007 | 06:15 PM
BlackTBird's Avatar
so they made 98 trans ams with no TC?
Old Sep 7, 2007 | 06:16 PM
BlackTBird's Avatar
wow...
BlackTBird's Avatar
wow...
Old Sep 7, 2007 | 06:21 PM
TransFan's Avatar
i dont have traction control. strange it does say tcs in my guage deals. but low traction light always comes on beats me
Old Sep 7, 2007 | 06:22 PM
SSkillz's Avatar
Yes they did mine is a 98 with tcs
Old Sep 7, 2007 | 06:30 PM
BlackTBird's Avatar
awesome.
but eveytime i try to luanch the back wheels/ rear end lift up and hit the pavement several times. as if traction control was on. i dont know why that occur
Old Sep 8, 2007 | 05:29 PM
ez98ls1's Avatar
If you had TC when the tires spun the accelerator pedal would push back on your foot and the car would fall on its face.
Old Sep 9, 2007 | 11:21 AM
coocooknu's Avatar
awesome.
I think what your talking about here is wheel hop. Has nothing to do with your TCS at all, happens to almost all of us at sometime with stock suspension.
Old Sep 10, 2007 | 10:18 AM
Cld069's Avatar
If you did have TC then as soon as you lost traction your engine would bog down and your accel. pedal would pulsate hence stopping wheel spin and giving you traction. If this is the case for you, and you have no way of shutting it off, well that pretty much sucks.
Old Sep 11, 2007 | 08:03 PM
mikenews's Avatar
Sure you don't have a "fake" ta? Or maybe the firebird formula with the ls1 didn't offer tcs... just my 2cents
Old Sep 11, 2007 | 08:49 PM
DuronClocker's Avatar
No, you could order a T/A or Z28 without TCS/ASR.
All gauge clusters will have the spot for "ASR OFF", but this just won't ever light up on a non-TCS/ASR car. GM just produces one gauge cluster instead of having one for each option.
The LOW TRAC light will come on whenever it senses wheel slippage, but the PCM will not do anything about it unless you have an ASR-equipped car with the system on.
Old Sep 12, 2007 | 05:15 PM
SSkillz's Avatar
x2 He pretty much sum it up there
Old Sep 21, 2007 | 04:54 PM
BlackTBird's Avatar
thanks guys. the wheel hop issue is fixed with getting new suspension. what do u suggest is the best suspension drop wise and performance wise.
i was lookin at the eibachs. are they good
Old Sep 21, 2007 | 10:49 PM
mikenews's Avatar
no gots dude!
