taylor wire question
Old Sep 14, 2007 | 10:56 AM
stevensLS1's Avatar
Default taylor wire question
does anyone know the big difference other than price between the 409 wires and the thundervolt 50 wire. both are 10.4mm?
Old Sep 14, 2007 | 11:47 AM
Full-Force's Avatar
Taylors are junk, they are gonna reak on you and they will look ok on the outside. Get you some MSD's.
Old Sep 14, 2007 | 11:48 AM
Full-Force's Avatar
Taylors are junk, they are gonna break on you and they will look ok on the outside. Get you some MSD's.
Old Sep 14, 2007 | 01:55 PM
jam99's Avatar
My buddy has taylors and has no complaints. I've used msd's on both of my f-bodies. I would just go with the msd's.
Old Sep 17, 2007 | 09:51 AM
radkon's Avatar
I've been running the Taylor thundervolt 50's for 2 years without any issue.x Not sure what the diff is between them and the 409's though.
Old Sep 17, 2007 | 11:57 AM
bczee's Avatar
IMO, as short as the wire are.. there will be very little voltage drop. Suggest you drop a email or call Taylor. Construction seem to be the most noticable different as well as the Boot.
409's discription:
A tightly woven, heat-treated fiberglass braid is applied over 100 percent pure silicone 8mm ignition wire. 100 percent silicone Pro Boots bonded to the wire, which features vibration-proof, double-spring locking plug terminals. The Sprio-Wound core is designed for use on multiple spark discharge systems, on-board computers, and electronic ignitions where RFI suppression is required.
50's description:
The 10.5mm wires use a ferrite spiral-wound core made with an exclusive copper/nickel alloy bonded by a conductive acrylic latex cover. Other features include a heat-treated fiberglass braid, a triple-silicone outer layer, and silicone boots.
Try a internet search next time to the manufactor web site or others.
Old Sep 17, 2007 | 12:01 PM
5301113's Avatar
MSD wires work well with f bodys. Most people here use MSD wires
