LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Pacesetter's finally in... (https://ls1tech.com/forums/generation-iii-external-engine/795192-pacesetters-finally.html)
DubyaSsixTA Oct 8, 2007 12:18 AM
I got my Pacesetter Lt's in around 2 years ago, but lost my job and couldn't finish the entire exhaust project (LT's, H-pipe, magnaflows 4X9s dumped). Finally, after a positive financial turn, a weekend and with the help of some good friends (thank you if you are reading this), they are in. Install went well, fitment is pretty good, and they simply look great!
How long after the install should I check the bolts? I remember reading this somewhere, searched for it, but couldn't find it. Any other random tips are appreciated.
I also drove roughly 50 miles with open headers. While I didn't get down on it too hard, the sound was glorious:devil:
01CamaroZ28 Oct 8, 2007 12:22 AM
after a couple hundred miles you should check em
matt94z Oct 8, 2007 12:48 AM
After a few heat cycles.
LS1 FORMULA Oct 8, 2007 01:31 AM
Keep checking for the next few mounths also. Them sneeky little buggers will try to work out after a few months.
2K2WS6TA Oct 8, 2007 06:47 AM
I checked mine after 2 weeks, found a couple loose, retorqued them and they've been tight ever since
DubyaSsixTA Oct 14, 2007 01:40 AM
Thanks for the replies, everyone. Hopefully I can get the rest of the exhaust on asap.
© 2026 MH Sub I, LLC dba Internet Brands
