spark plug gap?
Old Oct 8, 2007 | 01:31 AM
harlesjohn's Avatar
Default spark plug gap?
whats best gap on plugs for the 04 gto? ls1 duhh
Old Oct 8, 2007 | 08:58 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Just use what the factory manuel says (I think .060)
Old Oct 8, 2007 | 09:50 AM
radkon's Avatar
+1 a lot of folks are claiming .040 but the actual spec is a big .060
Old Oct 9, 2007 | 11:26 AM
chrismorales75's Avatar
.060, only reason to go less is if you run boost or nitrous.
Old Oct 9, 2007 | 11:18 PM
Black99CamaroSS's Avatar
It is not a bad idea to set it alittle narrow when you gap them because they tend to spread out after awhile. Don't set it too narrow or your spark will be small and weak to ignite the charge.
Old Oct 9, 2007 | 11:50 PM
Evans752's Avatar
I set mine at .050. NGK TR55 the regular ones.
